Schottky Rectifiers
With a 1.1-mm height and 4.8 X 6.7-mm footprint, the family of miniature-packaged MOS barrier and planar Schottky rectifiers handle voltages from 20 to 100 V and currents from 3 to 12 A.
All the devices feature a low forward-voltage drop and special wide-bottom-plate designs that provide greater heat dissipation than other packages of similar sizes. The single or dual-chip, surface-mount SMPC (TO-277A) package features solder pads that are compatible with other SMDs, so no modification is needed to the PCB layout for use as higher-performing upgrades to existing devices.
Vishay Intertechnology Inc., 63 Lancaster Ave., Malvern, PA 19355, (619) 336-0860, vishay.com
