Programmable parameters control image resolution, frame rate, horizontal and vertical binning, gain, and offset. Specifications include asynchronous external CC1 and hardware triggering, pre-exposure, capture duration, electronic shutter, long-time integration, strobe output, and gamma correction from 1.0 to 0.45. The CameraLink interface includes 8, 10, or 12 bits/pixel selectable over one or two outputs, camera control, and asynchronous serial communication on a single cable. The IPX11M5 has a monochrome imager, while the IPX11M5C has a Bayer-filter color imager.
Imperx Inc.,
6421 Congress Ave., Boca Raton, FL 33487,
(877) 863-1654, imperx.com
Sept. 16, 2025
Sept. 16, 2025
Sept. 16, 2025
