Wheel-end brake
Wheel-end brake retrofits standard caliper disc and drum brakes found on most Class 1 and 2 vehicles (GVW less than 10,000 lb) and is completely enclosed and self-contained to resist wear and corrosion.
retrofits standard caliper disc and drum brakes found on most Class 1 and 2 vehicles (GVW less than 10,000 lb) and is completely enclosed and self-contained to resist wear and corrosion. Wet-type multiple disc brake features a spring-applied, hydraulic release design for parking and emergency braking and is equipped with a pressure override function for regular service braking. Maximum static torque rating for the parking/emergency brake function is 40,000 lb-in. at 0 psi, while the service brake override has a maximum dynamic torque rating of 30,000 lb-in. at 1,500 psi. At maximum torque, the brake has an initial release pressure of 500 psi and full release pressure of 600 psi. The spring-applied section of the brake requires 1.0 to 2.0 in.3 of oil, while between 0.23 and 0.46 in.3 of oil is needed for the service brake section.
MICO Inc., 1911 Lee Blvd., North Mankato, MN 56003, (507) 625-6426, mico.com
