The 400 Vac, three-phase input drive system achieves speeds up to 6,000 rpm with increased torque range to 629 in-lb peak. The units are configured with two analog inputs and outputs, seven programmable digital inputs, and three programmable digital outputs. The operation delivers 16.5 amps RMS continuous and 40.5 amps RMS peak, with support options including extended I/O, Devicenet, SERCOS, and MACRO.
More Information:
YET Motion
www.yet-motion.com.
Aug. 21, 2025
