Positioning Tables With Zero Backlash
Four different lines of motorized positioning tables produce zero-backlash.
Jan. 11, 2007
These positioning stages consist of ball-screw drives that provide both horizontal and vertical motion. The tables use posidrive and offer straight-line accuracy up to 0.0001 in./in. of travel. They can be used for one, two, or three-axis configurations and handle loads from 30 to 180 lb. The heavy-duty tables give 48 in. of travel, straight-line accuracy of 0.005 in./in. of travel, and a maximum speed of 18 ips.
Isotech Inc., 777 Schwab Rd., Suite T, Hatfield, PA 19440, (800) 314-3332, isotechinc.com
