New Products: Refrigeration Pressure Sensors
The P528 family of ceramic capacitiverefrigeration pressure sensors target high volume applications requiring ±2% or better accuracy over the normal –40 to 85°C operating temperatures, such as those in refrigeration compressors, rooftop chillers, and refrigerant recovery systems.
Oct. 9, 2008
The rugged sensors withstand high overpressure spikes, come in 0-to-15 to 0-to-500-psia pressure ranges, are powered by a regulated 5-V power supply that produces a standard 0.5 to 4.5-V ratiometric output, are temperature compensated, have EMI/RFI and ESD protection, and output signal stability. Available pressure ports /-27 NPT, …-18 NPT, and … SAE female threads with Shrader deflators. The sensors have an integral Packard Metri-Pak 150 electrical connector.
Kavlico Corp.
14501 Princeton Ave.
Moorpark, CA 93021
(805) 523-2000
kavlico.com
