ELASTOMER ADHESIVE RESISTS ABRASIONS
The compound reportedly combines the strength, chemical resistance, and adhesive properties of epoxy-based systems with the toughness, abrasion resistance, and flexability of polyurethane. It also resists thermal cycling, absorbs little water, is hydolytically stable, and has low moisture permeability. It stands up to salts, alkalis, acids, and many organic chemicals over a 60 to 250°F temperature range. EP30D-9 cures at room temperature and has a 100:15 mix ratio by weight.
Master Bond Inc.,
154 Hobart St., Hackensack, NJ 07601,
(201) 343-8983,
www.masterbond.com
Aug. 21, 2025
