CAN-compatible displacement controls
New pump-mounted electronic-displacement controls for Series 2 heavy-duty pumps offer an SAE J1939-compatible CAN interface.
New pump-mounted electronic-displacement controls for Series 2 heavy-duty pumps offer an SAE J1939-compatible CAN interface. Design features include electroproportional-pump-displacement control with a swash-position sensor; <1% hysteresis; a fully encapsulated digital control module with EMC certification; and setup, monitoring, and diagnostics through a PC-based GUI. The unit permits independent pump control via a centralized control system or PLC, or a direct operator interface through CAN-enabled joysticks.
Eaton Hydraulics, 14615 Lone Oak Rd., Eden Prairie, MN 55344, (888) 258-0222, hydraulics.eaton.com
