Linear Slides
Series SFP Slide Design 6 features rail bearings for high rigidity and moment capacities.
Series SFP Slide Design 6 features rail bearings for high rigidity and moment capacities. The precision bearing system reportedly enhances performance in severe-duty applications and improves service life. The units offer optional travel adjustment, adjustable cushions, and stop pins. A wide selection of shock absorbers lets users tailor a slide to an application. Internal stop pins in the end caps eliminate damage if shock absorbers or travel adjustments are improperly set in the field.
PHD Inc.,
Box 9070, Ft. Wayne, IN 46899,
(800) 624-8511,
phdinc.com/sfp
