M3 Threaded Quick Disconnect for Fluid
The internal end is made of brass with a stainless steel external end, the entire assembly weighs 3.4 g. The brass-internal end has an automatic shut-off valve, is only 16.7 mm long, and has a 6-mm hexagonal body.
The stainless steel external end includes a captured O-ring seal that provides a leak-tight connection, is about 11 mm long, and has a 5-mm hexagonal body. Typical applications include instrumentation devices, portable fuel cells, UAV aircraft, and medical and laboratory equipment.
Beswick Engineering Company, Inc., 284 Ocean Road Greenland, NH 03840, (800) 354-5014 www.beswick.com
