Compact, Two-Bit Encoders
March 22, 2007
The EN Series of two-bit gray-code incremental encoders come housed in 11, 12 and 16-mm packages.
The EN Series of two-bit gray-code incremental encoders come housed in 11, 12 and 16-mm packages. The EN11 generates 20 pulse/rev, features top and side-adjust encoders with metal shaft and bushing, threaded and plain bushings, and optional push-on switch and detents. EN12 and EN16 create 24 and 12 or 24 pulses/rev, respectively. The encoders are dustproof and have a rotational life of 30,000 cycles. They operate in temperatures from –30 to 85°C.
BI Technologies Corp.,
4200 Bonita Place, Fullerton, CA 92835,
(714) 447-2345,
bitechnologies.com
Aug. 22, 2025
Aug. 22, 2025
Aug. 21, 2025
