Wire-Stripping Pot
Jan. 12, 2006
The Magnet Wire Stripping Pot removes film insulation from wires of all sizes and configurations.
Wires are dipped into the stripping solution to quickly remove insulation. The process does not mechanically stress or abrade conductors. The DSP1 unit has a basic temperature control. The DSP2 has programmable control for selecting and maintaining an exact temperature. Both models are available in 115 V 60 Hz or 220/240 V 50/60 Hz. Custom-sized pots are also available.
Eraser Co., Box 4961, Syracuse, NY 13221, (800) 724-0594, eraser.com
June 27, 2025
June 25, 2025
June 25, 2025
