Stopper Cylinders
Stopper cylinders come in 32, 40, and 50-mm bores, seven rod-end styles, and with adjustable roller direction.
Magnetic pistons are standard so magnetic sensors can be mounted on cylinder surfaces when input signals are required for controllers. The cylinders can be single acting with springextendedrod, double acting, or double acting with a built-in fail-safe extended rod.
Fabco-Air Inc., 3716 N.E. 49th Ave., Gainesville, FL 32609, (352) 373-3578, fabco-air.com
