Watertight Ethernet Ring Switch
The five-port IP67 Sealed Industrial Ethernet Switch (ET-5RS-IP67) features Real-time Ring capability for superfast switchover on network failure to keep the system up and running.
The switch mounts easily to machines or flat surfaces in the harshest environments. Surrounded by a rugged fiber-reinforced enclosure, the switch is equipped with Amphenol RJField connectors rated to protect against water, oil, dust, and vibration. Operating temperature range is 40 to 75°C. Real-time traffic prioritization with QoS assures delivery of real-time data, improves network utilization, and lets users set priority assignments.
Sixnet, 331 Ushers Rd., Box 767, Clifton Park, NY 12065, (518) 877-5173, sixnetio.com
