Dual-Pushbutton Switches
Nov. 17, 2005
The HW7 dual-pushbutton switches operate on-off or up-down applications.
The switches come with a momentary or mechanical interlock option, which keeps users from pressing both buttons simultaneously and activating two contacts at once. The devices come with a standard center pilot light in full voltage and transformer types illuminated with LED or incandescent lamps.
Idec Corp., 1175 Elko Dr., Sunnyvale, CA 94089, (800) 262-4332, idec.com
Was there once life on Mars? To answer this question, NASA sent its Perseverance rover to take soil samples to be brought back to Earth. The mission was the culmination of an ...
Oct. 1, 2025
Nerve damage is hard to repair and success rates are relatively low. But now, thanks to the advantages of spider silk - and an exacting drive system - nerve repair has a much ...
Sept. 24, 2025
Discover proven approaches to streamline communication, strengthen partnerships, and drive efficiency across your supply chain in this Autodesk webinar.
Sept. 23, 2025
Boost your manufacturing capabilities with top-tier conveyor technologies. Learn about selecting the right motor system for powered conveyors in this exclusive whitepaper.
