Small-Sized Accelerometer
The SSA-1000 solid-state accelerometer is assembled using military-grade construction techniques with production controls and inspections associated with military-certified quality systems.
Electrical connections are via solder terminals or shielded cable. Frequency response is factory set for dc to 100-Hz in. ±2 gm and ±10-gm ranges. Wideband response versions are available.
Columbia Research Laboratories Inc.,
1925 Mac Dade Blvd., Woodlyn, PA 19094,
(800) 813-8471, columbiaresearchlab.com
