Linear-Slide Systems
The combination of MDrivePlus (integrated motor and electronics) with screw-driven linear slides provides superior linear speed and accurate positioning with smooth motion and low noise.
Linear-slide leads of 0.10, 0.20, 0.50 and 1-in. travel/rev can attain speeds of 60 ips. The system provides torsional stiffness and stability for its size and weight. The slide includes a precision aluminum guide and wear-compensating, antibacklash-driven carriage with precision-rolled stainless-steel leadscrew. Slots accommodate sensor-bracket mounting onto the slide with provisions for mounting a flag onto the carriage.
Intelligent Motion Systems Inc., Box 457, 370 N. Main St., Marlborough, CT 06447, (860) 295-6102, novantaims.com
