I/O for Lighting
The 750-641 Dali (Digital Addressable Lighting Interface) Module permits more-efficient monitoring and control of building lighting.
I/O FOR LIGHTING
Special software lets designers create function blocks for controlling standard controls and the Master and Advanced Master function blocks for advanced Dali functions. The module can also communicate to over 46 Dali ballasts and digital outputs can control relays and solenoids. Analog inputs can be used for temperature control and light in the room, and analog outputs can be used to control the HVAC. The Dali module can be programmed to control functions affected by time of day, seasons, and flashing sequence for emergency.
Wago Corp.,
N120 W19129 Freistadt Rd., Germantown, WI 53022,
(800) DIN-RAIL,
www.wago.com
