Cable-Entry Systems
KDL/E cable-entry systems eliminate the need for cutting plugs.
Oct. 6, 2005
Features include high packing density (up to 20 cables when using the twin grommet), standard connector cutout (e.g., Harting, Wieland, etc.), click system for quick assembly/disassembly (1.5 to 2-mm wall thickness), bolt-on option, IP 54 protection, VDE-approved, and cable diameter from 3 to 16 mm.
Murrplastik Systems Inc., 2367 N. Penn Rd., Suite 200, Hatfield, PA 19440, (215) 822-7625, murrplastik.com
