Hytrel-Lined PVC tubing is a coextruded product used in appliances, lawn and garden equipment, laboratories, vending machines, propane-gas delivery, air sampling, computers, floor-care equipment, thermal protection, and general fluid transfer. It is designed to replace reinforced PVC hose in many applications. The Hytrel liner is designed for resistance to oils, high temperatures, and gas permeability. All materials are FDA sanctioned for use with food-contact surfaces, and the tubing withstands repeated autoclaving with no separation of layers.
