Software Helps PLM Handle Large Files
S-Series Application Acceleration Blueprint reduces download and assembly times to seconds for large Solid Edge files.
Aug. 23, 2007
S-Series Application Acceleration Blueprint reduces download and assembly times to seconds for large Solid Edge files. The program uses Solid Edge Insight, the built-in manager for design data, to smooth engineering work. S-Series is useful when remote locations connect over wide-area networks to access the central data repository. Network latency in these cases can slow design operations. S-Series has knowledge of application data at the object level, which lets manufacturing organizations maximize PLM and network infrastructure.
Certeon, 4 Van de Graaff Dr., Burlington, MA 01803, (781) 425-5200, certeon.com
