Industrial Network Server
The XPress DR+ industrial device server minimizes the need for hubs and cabling and sports ruggedized specs to connect PLCs, robots, process-control equipment, temperature-monitoring systems, or similar equipment.
The XPress DR+ combines Ethernet switch and networking technology. It supports two serial ports and two 10/100 Ethernet ports in a rugged DIN-rail case. It operates over a wide temperature range and includes Ethernet isolation as a safeguard for harsh environments.
Lantronix Inc., 15353 Barranca Pkwy., Irvine, CA 92618, (800) 526-8766, lantronix.com
