Strip Steel For Springs
Strip steel features precision hardness and consistency from coil to coil to provide spring manufacturers steel with no soft spots.
This eliminates a primary cause of spring failure. And with no soft spots to cut from the coil, less material is wasted. Strips can be ordered with several different tempering solutions and finishing options. It is packaged in either traditional flat-ribbon coils up to 60-in. OD or in compact oscillating coil spools up to 2,000 lb that offer longer uninterrupted production runs.
Blue Blade Steel Co.,
123 N. 8th St., Kenilworth, NJ 07033,
(908) 272-2620,
bluebladesteel.com
