Printing-Plate Mounting Materials
The R/bak family of cushion mounting products are for printing plates as used with corrugated material.
Sept. 1, 2005
The mounting material is an advanced microcellular urethane with open-cell construction for exceptional energy absorption and resilience that acts as a pressure reducer and shock absorber for flexographic plates. R/bak materials let printers improve registration, reduce dot gain, decrease plate deformation, maintain ink density, and use finer screens for finer line work. R/bak S-plate cushions and carriers come in two hardnesses: R/bak SF (firm) and R/bak SS (soft). The general-purpose R/bak U cushion can be cut, shaped, and mounted to even the smallest diameter cylinder.
Rogers Corp., One Technology Dr., Box 188, Rogers, CT 06263, (860) 774-9604, rogerscorporation.com
