High-Temp Seals and Gaskets
TriClad seals and gaskets are designed for use in heavy-duty diesel engines, from exhaust manifolds and EGR systems to turbochargers and cylinder heads.
TriClad is made from Thermafoil and Thermabraid graphite and a range of high-temperature metals. The seals are used in critical engine joints at temperatures exceeding 1,000°C.
EGC Enterprises
140 Parker Ct.
Chardon, OH 44024
(800) EGC-0211 or (440) 285-5835
www.egc-ent.com
