Rack-And-Pinion Drives
Jan. 6, 2005
A wide range of helical and straight (spur) tooth rack-and-pinion drives are available off the shelf.
The drives handle such applications as axes requiring precise positioning and repeatability, traveling gantries and columns, pick-and-place robots, and material-handling systems. Capabilities include metric pitches from module 1.0 to 10.0 and linear-force capacities to 31,000 lb. Standard rack-segment lengths up to 3 m are available, with unlimited travel lengths possible by mounting segments end to end.
Atlanta Drive Systems Inc.,
Route 34, Unit D-10, Wall Township, NJ 07719,
(800) 505-1715, 1775, atlantadrives.com
Sept. 16, 2025
Sept. 16, 2025
Sept. 16, 2025
