Nitrogen-Gas Springs
The U.01775 joins the Ultra Force (U) Series of nitrogen-gas springs.
Featuring a 19-mm-diameter body with an 11-mm-diameter rod, the spring provides over 380 lb of force on contact. Available stroke lengths are 7 to 125 mm.
Dadco, 43850 Plymouth Oaks Blvd., Plymouth, MI 48170, (800) 323-2687, www.dadco.net
