Swing-Handle Latch
Nov. 9, 2006
H3 Swing-Handle multipoint latches accommodate numerous size, configuration, and security options.
The handle stores in the latch body and pops up for use. The housing, handle, and cover all are of glass-filled nylon for low weight, high strength, and corrosion resistance. The latches fit door-panel thicknesses from 1.5 mm (0.06 in.) to 3.2 mm (0.125 in.). Optional ramp cams help doors stay snug to minimize rattles.
Cams handle grip dimensions from 4.5 mm (0.18 in.) to 42.5 mm (1.67 in.). A built-in lock cylinder accepts a standard PK lockplug, tool-access drivers, or DIN profile locks as required by some European standards. Locks can have single, multiple, or custom key codes.
Southco, 210 N. Brinton Lake Rd., Concordville, PA 19331, (610) 459-4000, southco.com
Discover how pump motor parameterization provides unprecedented control capabilities, allowing KNF to tailor pumps to your exact needs for increased productivity, extended pump...
July 28, 2025
Ensure accuracy and reliability in your lab. Discover how KNF's advanced food testing equipment provides the precision you need for critical analysis and results.
July 28, 2025
Explore the vital role of KNF pumps in cutting-edge fuel cell technology. Learn how our innovative solutions contribute to efficient and reliable energy systems.
July 28, 2025
Unlock optimal pump efficiency by understanding suction height. This essential guide explains how to prevent common issues and ensure peak performance for your applications.
