The DIN-Rail mountable GTS500 5-Phase Driver is operated from a standard 24-Vdc power supply and features power LED display. Other features include an auto current-down function, the option to set the driver at 0.75 pr 1.4 A, a resolution switch to power the motor at full or half step, and a panel that provides user with signal inputs. The unit weighs 180 g and is 50 × 81 mm.
Nyden Corp.,
2610-B N. First St., San Jose, CA 95134,
nyden.com
Sept. 16, 2025
Sept. 16, 2025
Sept. 16, 2025
