Product Spotlight: Right-Angle Photoelectric Sensors
The sensors produce high-intensity, pulsed, visible red (660-nm) light for high immunity from interference from other bright lights. A fourth-wire output alerts the control system if there is dirt buildup during operation so any deposits can be removed before object detection becomes critical. Housed in a M18 metal housing, the sensors feature high shock resistance, 10 to 30-Vdc voltage range, overload protection, and are short-circuit and inverse-polarity proof. The units are also stable from 25 to 55°C and can switch output current of 200 mA.
Contrinex Inc.,
2 Business Park Rd., Old Saybrook, CT 06475,
(866) 289-2899,
contrinex.com
