Motion-Control Couplings
A new line of motion-control couplings provides accurate transfer of motion between two rotating shafts, compensating for parallel, angular, and axial misalignments.
May 25, 2006
To cover multiple markets, the line includes Beam, Oldham, Mini-Jaw, Bellows, Mini-Soft, Mini-Disc, and Curved Jaw styles with zero backlash requirements. Maximum temperature tolerances on some styles reach 300°F. For high-speed operations, the GS Curved Jaw mini coupling has a maximum of 31,800 rpm, while the Bellows clamp style is designed for higher torque and bore capacities.
Lovejoy Inc., 2655 Wisconsin Ave., Downers Grove, IL 60515, (630) 852-0500, lovejoy-inc.com
