USB Drive Combinations
Industrial and panel PCs have USB 2.0 interfaces located on the IPC, as well as the automation panel. USB drive combinations include a DVD-ROM/CDRW drive, a floppy-disk drive, and two USB interfaces (Type A and Type B).
May 11, 2006
A CompactFlash slot works with Type I and Type II cards and with Microdrive miniature hard disks. All drives and the Type A USB interface are accessible from the front of the PC. The drive combinations mount in a switching cabinet cutout with the supplied mounting angles. An optional front door provides IP65 protection.
B&R Industrial Automation, 1325 Northmeadow Pkwy., S-130, Roswell, GA 30076, (770) 772-0400, brautomation.com
