Compression And Extension Dampers
A full line of compression and extension dampers is for applications where a heavy load or door must lower or swing in a controlled motion at constant speed.
Sept. 1, 2005
The dampers are forceabsorbing devices and come in two types to control speed in either compression or extension, depending on the mounting position. A piston with a small orifice that must pass through hydraulic oil controls speed. The devices are made in rod/tube-diameter sizes from 0.24 0.59 in. to 0.315 0.87 in., with stroke lengths from 2 to 7 in., extended lengths from 7.9 to 19.7 in., and maximum load capacities from 50 to 100-lb load/damper. Heavy, medium-heavy, medium, medium-light, and light-damping dampers are available.
H. A. Guden Co. Inc., 99 Raynor Ave., Ronkonkoma, NY 11779, (800) 344-6437, guden.com
