Contouring Control
The TNC 320 is a full-function control that incorporates the best features of the high-end iTNC 530 control, including the ability to control five axes, but costs less.
Aug. 24, 2006
An analog drive interface makes it suited for existing drive systems on retrofit applications, and one-piece construction minimizes cable runs. A 15-in. TFT color flat-panel monitor displays programming graphics and on-screen user support. A powerful main computer includes many onboard cycles to simplify most machining operations, including drilling, milling, and workpiece probing.
Heidenhain Corp., 333 E. State Pkwy., Schaumburg, IL 60173, (847) 490-1191, heidenhain.com
