High-Pressure Greases
The family of Staburgas greases, based on mineral oil and barium complex soap, are rolling bearing lubricants that provide corrosion and wear protection.
NBU 8 EP is a high-pressure lubricant for bearings that see high specific loads and ambient media and water. NBU 12/300 KP absorbs pressure, resists water, and is for use in drafting equipment on upper and lower rollers, tension and eccentric rollers, cardan shafts, and rolling bearings in fans and ventilation systems. NBU 4 (for high-speed roller bearings) and NBU 12 (for medium-speed roller bearings) are lubricating greases that provide good load-carrying capacity and sealing effect, in addition to being resistant to water, ambient media, and many diluted alkaline and acid solutions.
Kluber Lubrication North America L.P., 32 Industrial Ave., Londonderry, NH 03053, (603) 647-4104, kluber.com
