Brush DC Servo Driver
The EZSV10 measures 0.95 1.4 0.6 in. (24 35 15.24 mm) and requires little to no tuning when used with most motors measuring less than 1.5-in. diameter.
June 2, 2005
A single four-wire bus (two power, two comm) provides connections for up to 16 units simultaneously. High-level commands accepted via serial port controls brushed dc motors up to 1.5 A continuous at 12 to 40 V. The system also executes commands in standalone operation using an onboard EEPROM for program storage. Its industry-standard communication protocol is compatible with devices that use the Cavro DT or OEM protocol.
AllMotion Inc.
5501 Del Oro Court
San Jose, CA 95124
(408) 460-1345
allmotion.com
