Tubing Parts Eliminate Leaks, Improve Flow
Custom Molding Tubing Parts are manufactured from PVC-based plastisol.
The dip-molded parts solve problems such as eliminating potential leaks; reducing labor costs as the parts are ready to install; purchasing and stocking only one finished product instead of tubing, fittings, and clamps; unimpeded fluid or airflow as there are no connections obstructing flow; improved aesthetics, space savings for tight areas; and overall weight reduction. Tubing material is also available in FDA, 3A, and UL flame-retardant grades.
NewAge Industries Inc.,
145 James Way, Southampton, PA 18966,
(800) 506-3924, www.newageindustries.com
