Compact DC Cooling Fan
Oct. 20, 2005
Available in 12-V G and J-speed models, the new San Ace 40GV cooling fan measures only 40 X 40 X 28 mm (1.57 X 1.57 X 1.1 in.).
The fan targets 1U server units, data-storage systems, copy machines, communications equipment, power supplies, and a variety of industrial equipment.
Maximum airflow is 0.68 m3/min (24 cfm) at 330 Pa (1.32 in. H2O) using only 7.2 W. Life expectancy is 40,000 hr at 60°C and is RoHS compliant. Optional features include a tachometer sensor and locked rotor sensor outputs, as well as PWM (pulse-width-modulation) control of the fan rotational speed.
Sanyo Denki, 468 Amapola Ave., Torrance, CA 90501, (310) 783-5400, sanyo-denki.com
Sept. 16, 2025
Sept. 16, 2025
Aug. 22, 2025
