Case-Drain Monitor
A new Case Drain Monitor is billed as a lowcost alternative to using a standard flowmeter for case-drain applications.
Sept. 16, 2004
Available for 1/2 to 1-in. pipe sizes and designed for convenient vertical, horizontal, or inverted installation, it provides dependable measuring accuracy of ±5% of range. The monitor features durable aluminum construction that makes it useful for outdoor/exposed applications and where frequent washdowns are required. Case Drain Monitors also carry a one-year warranty.
Lake Monitors Inc.,
2013 South 37th St., Milwaukee, WI 53215,
(414) 671-3577, www.lakemonitors.com
