New Products: Compact Splicing Connectors
The 222 Series Lever-Nuts compact splicing connector family includes a mounting carrier (222-500), strainrelief plate (222-505), and angled DINrail adapter (222-510).
The mounting carrier holds four 2-wire, three 3-wire, or two 5-wire connectors; is designed for vertical snap-on DIN-rail mounting or vertical or horizontal panel mounting with screws; and has molded-in terminal marking or optional self-adhesive marking strips. Conductors are arranged and secured using strain-relief tabs and cable-ties. Connector end stops secure the connectors in the carrier.
The right-angled DIN-rail adapter provides horizontal DIN-rail mounting for carriers in the 222 Lever-Nuts, 773 Wall-Nuts, and 273 Series Push Wire connector families.
Wago Corp.
N120 W19129 Freistadt Rd.
Box 1015
Germantown, WI 53022
(800) 346-7245
wago.com
