Slide-Sleeve Valve
The ultraminiature M3SV-N threaded slide-sleeve valve controls gas or liquid in an in-line configuration.
March 8, 2007
The ultraminiature M3SV-N threaded slide-sleeve valve controls gas or liquid in an in-line configuration. The 4.6-gm valve can be attached directly in a fluid circuit and requires no panel mounting. The two-way (nonventing) valve has no preferred flow direction and inlet is through either M3 internal threaded port. Maximum inlet pressure is 250 psig. The valve's flow orifice size is 0.6 to 0.7 mm in diameter. The device has a captured O-ring seal design for leaktight sealing. The valve comes in brass or stainless steel with Buna-N as the standard O-ring material. Optional O-ring materials are EPDM, fluorocarbon, and silicone.
Beswick Engineering Co. Inc.,
284 Ocean Rd., Greenland, NH 03840,
(603) 433-1188,
beswick.com
