Linear Actuators
The LP28 and LD28 are the first in the PROmech Series of linear actuators.
March 23, 2006
Features of the LP28 linear positioner include a travel range of 5 to 500 mm, several linear-bearing options, and various screw-lead and motor-size options. It can be fitted with an optional strip seal as well as home and limit switches. The LP28 is ideal for payloads up to 10 lb.
The LD28 offers greater screw and motor-design flexibility and works in applications requiring up to 10 lb of thrust. Travel range is 5 to 300 mm.
Parker Hannifin Corp., Electromechanical Automation Div., 5500 Rohnert Park, CA 94928, (707) 584-7758, parkermotion.com/promech
