Miniature Fluid-Power Tubing
High-performance polyurethane tubing, coiled polyurethane tubing, and high-pressure tubing is designed for applications in medical, dental, and industrial fluid-power systems where flexibility and reliability are required.
March 3, 2005
Polyurethane tubing resists kinking and abrasion and sports superior memory, elasticity, and resistance to water, ozone, oil, and grease. ID ranges from 1/16 to 1/4 in. Working pressure at 75°F ranges from 93 to 176 psi and 47 to 88 psi at 150°F.
Coiled polyurethane tubing has a maximum extended length of 10 ft with 8 ft of working length. It's available with one 16-in. straight tail and one 8-in. tail. ID ranges from 1/16 to 1/4 in., and custom configurations are available.
High-pressure tubing can be used with compression fittings. ID ranges from 1/32 to 0.170 in. Working pressure at 75°F ranges from 172 to 2,400 psi and 68 to 2,400 psi at 150°F.
Beswick Engineering Co. Inc.,
284 Ocean Rd., Greenland, NH 03840,
(603) 433-1188, beswick.com
