Micro DC-To-DC Converters
Midpower Micro dc-to-dc converters, in 50-W models at 3.3, 5, 12, 15, 24, 28, and 48 Vout, incorporate low-noise zero-current and zero-voltage switching.
Midpower Micro dc-to-dc converters, in 50-W models at 3.3, 5, 12, 15, 24, 28, and 48 Vout, incorporate low-noise zero-current and zero-voltage switching. These modules suit industrial and process control, distributed power, medical, ATE, communications, defense, and aerospace applications. The converters operate from 24-V nominal input, with an input range of 18 to 36 V, and will operate down to 16 V after startup. Efficiencies range up to 89% for the higher-output voltages. These RoHS-compliant (with F or G-pin option) units measure 2.28 X 1.45 X 0.5 in. (57.9 X 36.8 X 12.7 mm) with a height above board of 0.43 in. (10.9 mm).
Vicor Corp., 25 Frontage Rd., Andover, MA 01810, (800) 735-6200, vicr.com
