IEC 60320 Filtered C20 Inlet Power Entry modules target computer, medical, general purpose, and/or custom indoor type equipment applications benefiting from the combination of filtering and ac power entry for detachable C19 cordsets.
The module is configured with an IEC 60320-1-1 C20 inlet and a filter. It has a maximum rating of 20 A at 250 Vac. Features include robust screw mount, nickel plated, shielded enclosure; 6.35-mm (0.250 in) quick disconnect terminals; general purpose filter or medical, low leakage current filter; UL recognition, CSA and VDE approvals; and RoHS-compliant construction. Pricing starts at $28.46 per piece.
