New Products: Miniature Ball Valve
The subminiature ball valve comes in two standard configurations
Nov. 22, 2008
The subminiature ball valve comes in two standard configurations: The MBV-1010-303 is for applications requiring an on/off valve and for those requiring the selection of one of two possible flow paths, the MBVT-1010-303.
The MBV valve weighs only 9 gm and the MBVT,12 gm. The corrosionresistant valves are housed in 303 stainless steel (with a 316 stainlesssteel ball). Seal material is Buna-N, with EPDM and Viton (fluorocarbon) as options. All ports are tapped 10- 32 UNF. The valves are used in applications requiring 0 to 250 psi.
Beswick Engineering Co. Inc.
284 Ocean Rd.
Greenland, NH 03840
(603) 433-1188
beswick.com
