Machine Design
  • Resources
  • Members
  • Directory
  • Webinars
  • WISE
  • CAD Models
  • Advertise
    • Search
  • 3D Printing & CAD
  • AUTOMATION & IIOT
  • Robotics
  • Motion Systems
  • Materials
  • Video
  • Data Sheets
  • Topics
    Industry Markets3D Printing & CADAutomation & IIoTFastening & JoiningMaterialsMechanical & Motion Systems Medical DesignRobotics
    Resources
    Machine Design ResourcesWISE (Workers in Science & Engineering)Company DirectorySearch Data SheetsContributeDigital Edition ArchivesCSIA Exchange
    Members
    ContentBenefitsSubscribe
    Advertise
    https://www.youtube.com/channel/UCXKEiQ9dob20rIqTA7ONfJg
    1. Archive
    Product Spotlight: Bearings: Self-aligning ball bearings
    Nov. 23, 2008
    Available with cylindrical or tapered bores in diameters ranging from 5 to 130 mm, the MRC self-aligning ball bearings  come in open or sealed types and in various cage materials (polyamide, machined brass, or pressed steel).
    MRC self-aligning ball bearings are designed with two rows of balls with a common sphered raceway in the outer ring. The design promotes lower friction and temperature, less wear and noise, reduced stress on bearing cages and lubricants, and longer life.
    Available with cylindrical or tapered bores in diameters ranging from 5 to 130 mm, the bearings come in open or sealed types and in various cage materials (polyamide, machined brass, or pressed steel). The bearings are engineered with extended inner rings and special bore tolerances for easy mounting and dismounting.
    Sealed versions have contact seals on both sides to retain lubricant and protect against contaminants. Synthetic rubber seals resist oil and wear and are reinforced with steel inserts. The bearings’ longlife lithium-base grease performs at –22 to 230°F.
    SKF USA Inc., 1510 Gehman Rd., Kulpsville, PA 19443, (716) 661-2727, skfusa.com/mrc
    Smart Factory Solutions that Connect and Protect from Amphenol RF
    Nov. 28, 2023
    Stay Connected and In Control of Your Future Factories with Littelfuse
    Nov. 28, 2023
    Turn to NKK Switches for the Widest Range of Industrial-Savvy Electromechanical Switches
    Nov. 28, 2023
    Unlocking Operational Flexibility in Manufacturing with Industria IoT
    Nov. 28, 2023
    I already have an account
    New
    EXAIR Introduces PEEK ½ NPT Super Air Nozzle
    Using Natural Language Understanding to Power Productivity
    Intelligent Assistant Platforms Improve Conversations with Industrial Robots
    Most Read
    Machine Design
    • About Us
    • Contact Us
    • Advertise
    • Do Not Sell or Share
    • Privacy & Cookie Policy
    • Terms of Service
    © 2023 Endeavor Business Media, LLC. All rights reserved.
    Endeavor Business Media Logo
