The Rino P20 and P30 Series rightangle gearboxes have a backlash of 8 arc-min or less. The gearboxes have a single-piece stainless worm and input shaft, machined aluminumblock housing, dual ball bearings for shaft supports, and an output bore with optional stainless output shaft. Specifications include 36 lb-in. torque at 2,000-rpm input (higher torques at lower input rpm) and 5:1 to 120:1 ratios. The units are available with shaft input, NEMA-17 flanges, or custom flanges. The P20 size without flange is 1.6 × 1.9 × 0.9 in. and the P30 is 2.4 × 2.8 × 1.1 in. The gearboxes are designed for 24/7 operation.
Rino Mechanical Components Inc. 216 N. Main St. Freeport, NY 11520 (888) 260-7466 rinomechanical.com
