New Products: Needle-Bearing Cam Followers
The BBXCAM- CN Series of high-carbonsteel needlebearing cam followers have hardened and ground outer races
Jan. 9, 2009
The BBXCAM- CN Series of high-carbonsteel needlebearing cam followers have hardened and ground outer races and low-carbonalloy steel-hardened studs and inner races. The followers come in ½ to 4-in. IDs and have both hex and slotted heads. Lubrication is through the head end only and clamping torque is based on dry threads.
Quality Bearings & Components
125 Railroad Ave.
Garden City Park, NY 11040
(888) 276-4787
qbcbearings.com
