New Products: Inverter Sports Disconnect Switch
The SMVector Frequency Inverter now features an internal disconnect switch that removes power to facilitate service and maintenance
The SMVector Frequency Inverter now features an internal disconnect switch that removes power to facilitate service and maintenance. Use of the switch in decentralized “point-of-use” operations results in reduced downtime. The switch eliminates the need for a separate external disconnect switch and associated wiring. Because the switch is lockable in the off position, the motor can be serviced while still connected to the SMVector drive.
Lenze-AC Tech,
630 Douglas St., Uxbridge, MA 01569,
(800) 217-9100, lenzeactech.com
